Old 07-27-2007, 07:12 AM
patrickt patrickt is offline
That filter is tried and true; it is not the source of the problem. You do not have a Pond block from 1965, so ignore that as well. Those pressure numbers are below what they should be, so you have a real problem. I looked back on this thread and didn't see whether the builder broke the engine in on his dyno. If so did he note the pressures at that time? Or did the engine have good pressure on the dyno and only recently start experiencing low pressure issues?
