Old 07-27-2007, 12:38 PM
Rick Parker's Avatar
If you are running MSD or similar, check the 2 wire pin connector between the distributor and the control box. The smallest bit of corrosion will prevent the trigger pulses required from being transfered to the box. Hence no spark.
Rick
