Old 07-29-2007, 01:59 AM
WKB's Avatar
WKB WKB is offline
Cobra Make, Engine: Harrison Cobra, SC540 Roadster
Merv,
There are some big power nissans that are used in all types of motorsports using the R200 differential.
The R32 GTST rear end that is mainly used has a 4.3 to 1 ratio. The R32 GTR rear end has a 4.1 to 1 ratio. GTR rear ends can be used but as there are slight differences between the GTR and GTST rear ends and there is a fair bit more fiddling around to fit them(I speak from the experience of fitting a GTR rear end).
A couple of cobras I know that have 4.6 ltr quad cam fords and GTST rear ends that use second gear to take off most of the time. One has a T56 and the other one has a T45 gearboxes.
As Craig said the best way to find out what is right is to drive the car first, then modify if needed to suit your needs.
Warren
