Old 07-29-2007, 09:19 AM
bermblaster41 bermblaster41 is offline
Cobra Make, Engine: Hurricane Motosports
I am leaning towards a fuel supply problem to my pump. With the engine off it still cavitates and pressure low. {Only when hot} What type of fuel pickup Are you guys using. The one I replaced had a 1/2 plastic straw up to a hard 90 metal fitting{choked down to 3/8}. I replaced the pichup with 1/2 allum With a 90degree bend using tubing bender{No kinks in the line}. I had this problem before I replaced fuel pickup.. Dyno would be great but even more of a waste of time and money. I know this has to be something simple. I do plan on taking to a dyno but have to get the fuel supply problem fixed first. Thanks again Bermblaster
