  #51 (permalink)
Old 07-29-2007, 06:32 PM
lineslinger's Avatar
lineslinger lineslinger is offline
Cobra Make, Engine: 427 S.O. Dual Quad / Cobra undecided
Originally Posted by lineslinger
Do post some pictures of your plumbing if you can Priobe.
10 - 15 psi at idle is not good at all, way too low. If it was my engine I would not run the engine until you get the pressure issue diagnosed. If you are running twin filters you should most certainly be using a high volume oil pump IMHO.
Old dog is dead on with his advice.
Other questions I might ask is are you running restrictor plugs in your heads, what about the condition your valve stem seals, amybe a clogged oil pump pick up? Possibly a loose seal/connection in the pump pick up attachment area, there is a lot to consider.
If your plumbing is correct and you have the HV oil pump in place you might want to consider the settings, or lack thereof, of your oil pressure relief valve at the back of the block as well as the pressure relief/bypass setting in your oil pump. I shimmed out the pressure relief spring in the oil pump to boost pressure and eliminated the engines pressure relief valve all together.
With these modifications, at idle, I am seeing 70 psi. In the upper rpm range the OP is right at 100 psi. Many will say this is too high but I would disagree for many reasons, but thats another thread.
Lets see some photos when you get a chance.
Priobe,
Really glad for you and figuring out what was wrong.
I don't see any reason to replace your oil pump, the Melling has a good reputation and if you do desire a pressure boost you can shim the pressure relief spring in the pump. At this point maybe you should consider putting the motor together so you can start it and get some pressure readings.
Don't hook up everything just yet, get the oil pressure readings first. If you are getting the OP readings desired you may at that point decide if you want to boost the pressure or not.
While you have the tranny disconnected you will be able to inspect the rear of the engine, the crank seal and the various plugged ports for any oil seepage.
