  #31 (permalink)
Old 07-30-2007, 07:08 AM
priobe's Avatar
priobe priobe is offline
Cobra Make, Engine: E-M Cobra Ford FE 427 w/ Webers 48 IDA
Lineslinger,
In your quote you mentioned that you bypassed the pressure relief valve in the block all together.
How did you di that ?
Did you remove the pressure valve / spring and not install anything in the hole ?
Also,
Where could I get the plug for where the oil pressure spring goes in the oil pump?
Thanks
