  #34 (permalink)
Old 07-30-2007, 10:46 AM
priobe's Avatar
priobe priobe is offline
Cobra Make, Engine: E-M Cobra Ford FE 427 w/ Webers 48 IDA
patrickt,
I am befuddled as well. Here is the way I determined the problem.
I reinstalled the oil pump and took an old oil pick up and cut the screen off. Then I installed a hose on the end of the pickup and placed the other end in a bucket of oil. I then had my brother in law attach a drill in the revere motion to pump oil thoughout the block. I noticed seepage from the crank and cam but in the rear of the motor was Niagara Falls!!!
I removed the tranny and clutch. Removed the allen plug and there it was installed incorrectly.
Now if you remove this plunger setup from the back of the block I am believing you will have a major interal oil leak like I experienced unless you insert a cylinder the size of the spring or plunger to block the holes in the block.
