  #56 (permalink)
Old 07-30-2007, 11:49 AM
priobe's Avatar
priobe priobe is offline
Cobra Make, Engine: E-M Cobra Ford FE 427 w/ Webers 48 IDA
Originally Posted by priobe
patrickt,
Now if you remove this plunger setup from the back of the block I am believing you will have a major interal oil leak like I experienced unless you insert a cylinder the size of the spring or plunger to block the holes in the block.
Is anything installed in place of the oil relief valve?
If nothing is installed and then me having the this installed incorrectly would not be my problem of the interal leak.
It looks like the way the valve is designed with the 2 grooves on the plunger is to releave the pressure when needed. When the pressure is "normal" with the plunger installed will block 2 passages until the pressure is builds up to be released.
2nd question:
In your quote it states "the relief valve in the back of the block will operate at typically 55-65 psi".If the valve is installed then those of us with the relief valve installed will only have 55- 60 psi of oil pressure regardless of what we do to the pump.
Again,
These are only questions that I am asking to better understand hoe the oiling system works. I am not trying to make any statements.
