Old 07-30-2007, 01:25 PM
Well I see I'm in good company Lineslinger! I'll post some pics of the body later, which is in really good shape. The engine smoked and the trans was hard to shift without double clutching (bad synchro's). I suspect the smoking engine was mostly a result of the completly worn out rocker arm shaft/bushings dumping oil onto the valve guides. A good 'freshen up' should set things right. The suspension and brakes also require work though.
