Old 07-31-2007, 05:54 AM
63mercury's Avatar
63mercury 63mercury is offline
Cobra Make, Engine: Scratch building frame,FFR Mkll body ,302w, and T5 trans, 3.0 rear.
Default Dimensions Please
Does anyone know what the inside measurement is between backing plates on the Cobra roadster solid rear axle? I have a Ford 9 in that measures 54 in and would like to know if it will work. The other dim that might help is across the flange where the wheel bolts to, that would even help.
Thanks Carl.
1963 Mercury Monterey 460+ .060 .//Cobra clone, Scratch build frame /302/ T-5 WC / 3.00-9in/FFR mkll body (Broken but repairable) /91 Lincoln Wire Wheels // : N.S.M.C Charter/Life Member// Die Hard Blue Oval Nut
The finish is better than the beginning. Ecc7:8
