Thread: Stuck Clutch
Old 07-31-2007, 04:20 PM
Burgs's Avatar
Burgs Burgs is offline
Cobra Make, Engine: Hurricane 427S/C, KC/Pond aluminum 427/482 SO, TKO 600
Originally Posted by khansmith
the screw driver to pry off the plate(can't do this without taking off the bell housing which I want to avoid)
Without taking anything apart,... with someone in the car with the clutch pedal in, put the screwdriver thru the fork hole in the bell and pry. Mark that spot, turn the motor, and do it again. When you go all the way around, try the go cart ride one more time.
