Old 08-01-2007, 11:03 PM
Rebel1 Rebel1 is offline
Originally Posted by RoyTheBoy
Forgot to mention... My chassis is set up for Series 2 and takes the stock castor shims I mentioned in my last post. I had another look at your pic and 6mm seems a little excessive considering, mentioned, the G-Force is designed for the Jag suspension. You should only require shims for fine adjustment.
Regards
Roy
Not totally true.
Mine is set for 0 camber ( ie exactly 90 degrees to a flat surface) when sitting level and looks exactly like Stephens except I have series 11 uppers.
ie. at least 1/4" (6mm) of spacers between mount and pivot shaft.
Standard Jag shims are : 1/32" (.8mm), 1/16" (1.6mm) and 1/8" (3.2mm).
each 1/16" will alter camber by 1/4 degree.
However, as per earlier post, forget the standard jag shims as some kit manufacturers used chassis jigs which left a lot to be desired so the accuracy of placement of inner mount is suspect.
