Thread: Carb Preference
  #24 (permalink)
Old 08-02-2007, 11:13 AM
greg schroeder's Avatar
greg schroeder greg schroeder is offline
Cobra Make, Engine: Superformance, Roush 427R-095, Pro Systems carb, 2" headers, Buckshot Racefab side pipes, 10s off idle start
I'm sure there are many manufacturers that make carbs that would work great if turned and set up per application, but in my opinion if you're not capable of setting up a carb to perfection yourself just call Pro-Systems and run better while going faster.
I have small block Roush 427R-095. My particular 427R came with a Victor Jr. single plane intake and AFR 205 heads. I have two carbs in the attic that I don't use, but I did fiddle with when I got my car. One is the Roush supplied Holley 750 double pumper. It worked pretty good up to about 6000 rpm. The other is a Holley Avenger 870 vacuum secondary. I could never get the vacuum secondary to work well regardless of what spring I used in the little canister off to the side. I'm sure both carbs are fine for whatever purpose if they're set up correctly per application, but definitely weren't what I was looking for. I called Patrick from Pro-Systems looking for more. I originally asked for a carb that would accelerate in a straight line as fast as possible. For the most part this is what I like. After some discussion of my engine design I ended up ordering a Pro-Series 4150. He asked my zip code so he could tune the carb for my location and season. I got the carb, bolted it on and it absolutely hammered exactly the way Patrick said it would. It's like a light switch for power if desired and smooth as silk under casual acceleration. I can even cruise at 1500 rpm if I want to too, usually cruise about 1800 though. carb pic Dynojet
I'm in a car club that rents road courses a couple times a year to fart around, so I ordered another carb from Pro-systems for that purpose. I've not put it on the car yet because the other one is so much fun already. It sure is pretty though. carb pic
