Thread: Pulsating noise
Old 08-02-2007, 01:31 PM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
I have seen a few installations where the driveshaft was rubbing on the driveshaft hoop. Very few installs have the driveshaft installed dead-straight (side-to side that is) to the rear end, and I believe the straight-shot is not a desirable way to do it anyway. Could you have too much side to side angle in your drivetrain causing a binding? Maybe an out of balance driveshaft? Loose a weight on it? I'f also seen the old style parling brake cables rubbing on tires, axles and driveshafts
