Old 08-02-2007, 08:58 PM
GlynMeek's Avatar
GlynMeek GlynMeek is offline
Cobra Make, Engine: Lonestar Classics, 302 stroked to 347; Metallic British Racing Green
Guys, thought I might be able to help clear up some questions about Lizard Skin, as a US user with some experience. I applied it ALL over the underside of my body shell, wheel arches, and inside the engine compartment and the driver's cab as well.
1. COMPLETELY safe to put directly onto fiberglass.
2. Covers well, and actually has a pleasing, mottled surface with a slight rubbery texture.
3. I sprayed the inside of the engine compartment completely with my final color paint and there is NO problem about it adhering to the Lizard Skin.
4. You can actually get two types of Lizard Skin, one for heat and one for noise. I called the supplier about this, and was told that the 'heat' one works perfectly well for 'noise' insulation as well, so you only need the one type.
Hope this helps a little
Regards
Glyn
PS spent last week in Melbourne on business..dear god, you folks have AMAZING seafood!!!!!!!
Cave magister imperitus - Beware the inexperienced teacher
"No, I DON'T have an accent, this is how English sounds when it is pronounced correctly!"
