Old 08-03-2007, 08:42 AM
Rick Parker's Avatar
Default Webers on 289/302
I recently installed 48 IDA's on my 289 and ran across a small issue that I had not anticipated and wondered if any of you with similar installations had a solution (?) The distributor hold down bolt becomes very confined while using the intake manifold with 2 hoses going forward, instead of the type with a thermostat housing. I am considering a Buttonhead screw with internal hex. The regular 1/2" hex headed bolt is almost inacceble. Any other ideas????
Thanks
Rick
