Originally Posted by ceslaw
I still cannot understand how an engine can be free of leaks, use a quart every 300 miles and not put out some blue smoke.
Chuck
I've seen it before.
Did your builder use umbrella seals on the guides or the tighter passenger car type teflon seals?
On a racey engine, a lot of builders will use this type of seal and they tend to act like little metering pumps giving the valves a shot of
oil every time the valve cycles up and down. The metering of the
oil is so controlled, and so even, it doesn't show up as exhaust smoke, it just gets consumed and diluted with exhaust gas during the normal running of the engine.
The problem could be as simple as a missing seal, or a split seal...causing the guide in question to get more
oil then the rest.
Whatever it is, you'll need your detective cap and some patience to find it. I tend to subscribe to the guides/seals theory. I just don't see how an intake leak could draw enough oil in without making a vacuum leak bad enough that you'd either hear it or notice it due to lean misfire. I think the first thing I'd do is remove the cover, bring the bore in question up to TDC, pressurize the bore, pop the springs off, and inspect/feel the guides and stems for faults. Seems to me your trouble probably lies there.
