Old 08-04-2007, 08:04 PM
Zoom This's Avatar
Zoom This Zoom This is offline
Default Squeaking Suspension fix
For more than a year I put up with an intermittent suspension squeak in my SPF 1735. I have 18,000 miles on it. This chirping squeak sounded like it was coming from the left front, then the right front, then the rear, and lastly, under the dash. After lubing ball joints, urethane bushings to no avail, I put the car in the air and got out the WD-40 and aersol can of white grease. After lubing any and all rubber contacts points, I sprayed lube on the upper and lower spring perches, front and rear. Problem solved. Hell, I was ready to dip the whole car in WD-40 to get rid of that annoying intermittent squeak!
