Old 08-05-2007, 07:40 PM
Tony Cram's Avatar
Tony Cram Tony Cram is offline
Cobra Make, Engine: 1991 RMC 1966 427SC replica, 302 Cleveland, Edelbrock manifold with 600 Holley double pumper.
Default Series 1 versus 2
Steve,
I may have led you astray on the series one / two upper arms. (Sorry about that!!!) What I found was the Series 2 upper arms did not give me enough caster without doing some major surgery on the lower arms. The series 1 upper arms due to the different lengths gave me the caster I was after with enough adjustment with shims etc.
If I want more castor I would have problems with the setback on the front wheels.
If you have very heavy steering under parking you may want to consider getting Series 2 upper arms to reduce your caster a little as Rebel 1 has explained with the G Force setup.
Tony
