Thread: A sideways RMC
Old 08-07-2007, 08:53 PM
Rebel1 Rebel1 is offline
Check left hub pivot bearings as CHANMADD said. If you do normally have toe in then a worn left hub pivot bearing will toe out pointing both back wheels to the left.
Usually the left hub bearings fail first as that's the wheel you drop off the road more often.
Check lower control arm inner pivot bearings......not often they go because their is bugga all movement but lack of attention over time may cause one to fail.
Powerlok diff clutch pack gone on one side?
Just thinking out loud. Prolly something simple just gotta find it.
cheers
