Old 08-08-2007, 06:50 AM
Double Venom's Avatar
Double Venom Double Venom is offline
vettestr,
Thank you for believing me; my posts kept disappearing and thinking something was wrong with the system I finally realized it was my computer. My posts were there all along but for some reason they wouldn't show up when I came back to the thread??? That's it.
DON,
One more thing that may, not likely, but may cause a "hang-up" in your ignition is the "rack & gear" in the COLUMN (NOT the steering). As you turn the key in the ignition, the ignition moves a nylon round gear on a galvanized track pushing the rod to the ignition switch. A little white spray grease down the "tube" almost always fixes this problem. Not likely your problem but if the ignition switch proves out, check this little gear and rack.
Ed/DV
