Thread: Coolant
Old 08-08-2007, 03:17 PM
wtm442's Avatar
wtm442 wtm442 is offline
Beam Me Up Scottie
Originally Posted by dandascott
Thanks for all of the input. On a related topic - I am starting to install the sending units in the engine. I am told that the "correct" way is to seal the threads with a conductive sealant. The problem is that none of the parts stores have this.
Is this overkill ? Will the gauge readings be compromised if I use teflon paste ?
If anyone has used a conductive sealant where did you get it ?
Thanks,
Just use the teflon paste. There will be metal to metal contact when you tighten the fitting.
Warren
