  #21 (permalink)
Old 08-08-2007, 08:13 PM
GlynMeek's Avatar
GlynMeek GlynMeek is offline
Cobra Make, Engine: Lonestar Classics, 302 stroked to 347; Metallic British Racing Green
Stephen...you don't need any kind of special gun at all, in fact, a 'low tech' cheap gun works fine, and if you clean it quickly and well afterwards, there are NO ill effects at all. After all, it is just 'goop' you are spraying and it doesn't need to be THAT accurate. I sprayed one coat over everything, and then kept spraying over firewall and engine compartment again until I used it all up.
Glyn
Cave magister imperitus - Beware the inexperienced teacher
"No, I DON'T have an accent, this is how English sounds when it is pronounced correctly!"
