Below is a picture of the Ram-flo filters I currently have. They may work with your stacks but do not "slip-on." Takes a little time to remove or replace.
I had a pair of those ram flow filters on a Lotus Cortina with 40 DCOE's and couldn't get enough air through them to run at anything above idle! Switched to some modified K&N filters and it ran great.
This is probably your best bet for an affordable and efficient air filter. Scroll down to the Weber section for the applications. Available for both the IDA and IDF.
http://www.knfilters.com/Racing/customcarb.htm
FFR, 331 SBF dynoed 372RWHP@ 6100 RPM on 87 octane pump gas
