Old 08-11-2007, 11:12 AM
onefastmustang's Avatar
onefastmustang onefastmustang is offline
Cobra Make, Engine: CRII with a Stroked Windsor
On my MSD the coil gets its power from the MSD control module. The only wires I connected to the MSD are the PINK, White (Tach) and a ground. A mechanic buddy of mine recommended that if I needed to pull power for a coil I could do it from the same PINK wire or from a wire run to the alternator output.
Previously when I had the HEI all in one distributor it was just the PINK and White Wire to get it all running.
