Jay Bar:
When you lowered your Mustang you didn't change the rack, you moved it (hopefully) or put long spacers at the tie rod ends (bad). The distance between the inner pivots must be maintained and kept in an imaginary line between the upper and lower suspension pivots or it WILL affect the bumpsteer as previously stated, strictlypersonl is on the money, heed his warning . Shortening the tie rods does not correct the problem.
Rick
