Old 08-12-2007, 06:42 AM
Eljaro's Avatar
Eljaro Eljaro is offline
Cobra Make, Engine: Contemporary with 482 KC/SO, TKO600,IRS Jag/AMP, 3.54 Salisbury PL,
Rick,
you mean cylinder 5 or 6?
Check the jets. You may have dirt in the main or idle jet.
If you didn't blow air through all the webers galleries during assembly you may find some debris has got to the jets. Nothing else can cause that if your ignition is ok.
New carbs aren't 100% clean out of the box!
Nothing sounds better than a Cobra in a Tunnel !
