Old 08-12-2007, 12:43 PM
bkozlow bkozlow is offline
Cobra Make, Engine: built the molds and body composite construction
Default Gaskets
I have had no problems ever using Moroso number 93060, Blue colored valve cover gaskets. They are rubber molded over a steel frame. They are not cheap but do a great job. You should be able to get them at your local hot rod shop or Summit or Jegs. Even, if they don't show them in their catalog you just give either of the big distributors the catalog number and you can get it through them.. However, I recommend looking for a local source.
Bill K
