Old 08-13-2007, 10:13 PM
fsstnotch fsstnotch is offline
Originally Posted by CHANMADD
Huh!!!I thought you were talking rear ends?
you must have read the post right when I did.
We are talking rear ends, to fix rblong's problem
When pushed to hard, the 9" will pressurize itself to the point of pushing the gear oil out of the weakest point. If you are running a 9" without a vent.. I would HIGHLY suggest using one. If you use a vent, then that will be the weakest point and where all the oil will be pushed. If you don't... it'll go out somewhere else which will be alot more costly! A simple catch can with a breather will prevent spillage and over pressurization.
Bagram AF Afghanistan
