Old 08-14-2007, 09:51 AM
ground zero's Avatar
ground zero ground zero is offline
Cobra Make, Engine: 2006 SHELBY GT-H
Terry, this might not be your problem but I had a similar situation with #1967 with intermittent starting problems. What I found was that if I turned the key all the way to the right to start the car it wouldn't do anything, I turned the key slowley and it started every time. It seems as if there is a point in the ignition switch where it will start the car and if you go beyond that the switch would'nt activate the starter. Hope this helps. Dale
