  #21 (permalink)
Old 08-16-2007, 06:33 PM
Rwillia4's Avatar
Rwillia4 Rwillia4 is offline
Cobra Make, Engine: BDR #455, KC427W, TWM-FI
Jay is correct.
DOT 5 is not a good solution, two reasons: 1) is doesn't mix with the previous DOT3/4 in the system (which is difficult to remove from the system without fully removing the parts and cleaning seals,... 2) DOT 5 is NOT compatible with the o-rings and seals designed for a DOT 3/4 system
Don't fully understand? do a google search for yourself: "dot 4 change to dot 5". You will notice a trend for yourself. End of story: DOT 5 in your DOT 4 designed system is bad news. Unless you want to revisit this issue again a year or so down the line to replace more than fluid.
The advantage of an open forum is that everyone is entitled to an opinion; the disadvantage is you have to wade thru the "filler" to get a solution.
Uncltodd- do you still have your ride? I can make a copy of my manual and send it to you; PM me. You are not missing much if you have been at it for 3 years.
