  #33 (permalink)
Old 08-18-2007, 05:05 AM
Default Thank's Sizzler
Sizzler Thanks for the info. I was looking to save time. I have the pushrod tester kit. The motor is apart and this assembly is going to be a last minute thing. I was just looking to really get in the ball park with the lenght. Niether the heads or the motor block have been decked. I used a flat edge machinist plate and there is about a .002" raise around the sleeves for the cylinders. If the push rod. I am going to try and see if anyone has this setup for their motor with a hydro cam, crane lifters, and erson rockers on stock heads. At this time I was not going to worry about a .020" lenght problem. I am running a softer valve spring for the heads. Thank's again Rick L.
