Old 08-19-2007, 09:11 AM
patrickt patrickt is offline
What's even funnier is that Champion makes an anti-seize for spark plugs but then recommends against using it. Here was Autolite's position on anti-seize:
"We do not recommend the use of any anti seize products for installing spark plugs. Anti seize compounds are typically composed of metallic, electrically conductive ingredients. If anti seize compounds come in contact with the core nose of the plugs, it can lead to a misfire condition. Anti seize compounds can also have a torque multiplying effect when installing plugs. This can lead to thread distortion and thread galling resulting in cylinder head damage. Autolite spark plugs are nickel plated to resist the effects of corrosion and seizing. However, plug seizure is aggravated further when steel plugs are installed into aluminum cylinder heads for a long period of time."
