Old 08-19-2007, 09:29 PM
4pipes's Avatar
4pipes 4pipes is offline
Cobra Make, Engine: Kirkham #185, Shelby Alloy 482; sold
Ray, synthetics are not recommended for FE's with flat tappet cams. It's a separate problem than ring sealing. Crane cams states on their website that synthetics may be too slippery for the lifters to rotate adequately in their guides (not enough friction between the lifter and the cam), and that if the cars are not started regularly, the oil will drain off the cam faster than conventional oils.
Dave
