Old 08-20-2007, 08:21 PM
tc_sj's Avatar
tc_sj tc_sj is offline
Cobra Make, Engine: SPF#1751 CHP 427
Default battery brain mount ?
I just bought the battery brain and look like there is no room to mount the battery brain in the trunk of the superformance battery holder
can you share where do you mount the battery brain in your car, I was thinking to run a cable all the way from the battery to some where to the front but look like too much work for me
Thanks
Tan
Originally Posted by CobERA
Archrms,
I recently converted to a combination of start button and toggle switch and did away with the keyed ignition switch. For security I added a hidden kill switch in the cockpit. I also added a doo dad called a Battery Brain Type III. It hooks up to your battery and is designed to protect your battery from being drained to far when the engine is off. That feature isn't particularly important to me, but it also comes with a key fob remote that allows you to connect and disconnect your battery via the remote. My battery is in the trunk which I now just keep locked all the time. I figure this combination is about as secure as a keyed ignition switch. Just hope I can remember how it works each time I take the car out!
It's not authentic, but kinda fun. Throw a switch, push a button, and you're off!
