Old 08-21-2007, 09:37 PM
stephen low's Avatar
stephen low stephen low is offline
Sorry, should clarify in that I want a glossy look not a matt finish.
I meant that sanding of the epoxy coating would achieve a flat and keyed surface upon which to apply further coatings for a gloss outcome. Whether it just be further epoxy of a urethane overcoat.
I'd agree with not varnishing over another coating type but where the clear is a polyurethane is this such an issue?
I'm not sure whether the epoxy I have has much of a UV rating, as I'm guessing this rating can vary, is this so? And hence applying an epoxy only finish might be little better than applying a poor grade varnish.
At least I know the urethane clear I have is UV resistant, so I am still in a quandry as to what to use!
Auto clear obviously does work as I haven't seen too many sun damaged paint jobs, and I guess I could leave the dash somewhere that does clear coats and just wait for them to have a job in where they could also do the dash at the same time.
However I wouldn't mind keeping the coating application in my control if possible. Both time and cost constraints are then on me!
Further comment invited!
slowy
