08-23-2007, 05:54 AM
OK
Cobra Make, Engine: Fords
Originally Posted by Brent Mills
That's either the cam with too much overlap as Z. Ray suggests or it's a lean condition. The only reason I shy away from it being too lean is because you note that it starts happening after things are warmed up, which tends to make the A/F ratio go more rich. Maybe post your cam specs and your carb specs (idle/main jets, chokes, correctors, etc, etc).
Brent,
do you know the cam spec parameters for using Webers ?
thanks,
Z. Ray
'65 K code Mustang
'66 Galaxie 500
