Old 08-15-2001, 02:21 PM
Coloradocobra Coloradocobra is offline
My installation is temporary as I really don't have room for the gauge and it does not match my SW gauges. Assuming that you don't expose the O2 sensor to an excessively rich condition or to leaded fuel there is no problem leaving it in. The sensors are not cheap, however, so I intend to move mine to my Mustang after I get the Cobra sorted out. They supply a threaded plug with the bung kit that seals the bung when the sensor is removed. The O2 sensor that I bought from Autometer (Summit) is a three wire design - it has a heater. The gauge will work with other sensors and I beleive it also supports a one wire sensor. Apparently they all have the same voltage calibration.
It is my understanding that you can also tune secondaries - mechanical or vacuum. Better try it with a buddy in the car as it is hard to watch the gauge and the road while accelerating. The article I read suggested fully tuning the primary, idle, and power valve first. Power valve is tuned by selecting the proper vacuum setting and then modifying the fuel passage diameters. This involves restricting or opening and there is a kit someone sells that actually uses small jets to adjust this important setting. For example, I hear that the passages on doublepumpers are often small and the carbs are set rich. The combination works. If you lean out the primaries, you will end up lean under acceleration. In Colorado, the vacuum secondary carbs are set up with too big of a passage and it has to be restricted to lean it out.
Once these are set, then it is on to the secondaries. The same techniques apply and you now only adjust the secondary jets to acheive the best mixture. I understand that a trick some people use is to set the primaries a little towards the lean side and then run the secondaries a little fat. The thinking is that the richer condition will protect under full load and that the primaries are usually used under light loads. The danger here is that you can go lean before secondary tip in - the point when fuel actually begins to flow that could be harmful. With the air/fuel ratio gauge you can detect and correct the situation before any harm is done.
Gary
