Old 08-25-2007, 01:54 PM
David Kirkham's Avatar
David Kirkham David Kirkham is offline
Original Shelby Owner
DRIVE SHAFT INSTALLATION
Here are the goodies you are going to need to put in your drive shaft. You MUST pull the tunnel out to take the drive shaft out! (We are working on a fix for that, but I am not sure we will get it done in this life time).
This is what you will need:
Drive shaft
Drive shaft bolts (we only use aircraft bolts here--and throughout most of the car for that matter). Notice the cool looking 3/8 jet nuts. They have a reduced head on them to make them easier to get a wrench on in those tight places.
New cool BILLET drive shaft safety loop. Notice we connected the bottom of the safety hoop together at the bottom so we could safely run the ebrake cables (and other things) through the bottom of the loop and still have them protected from the drive shaft in case of drive shaft breakage. We have seen many kit cars (and original cars too!) that run fuel lines, brake lines, electrical lines and who knows what else RIGHT NEXT TO THE DRIVE SHAFT!!! IF THE DRIVE SHAFT BREAKS, THE FUEL LINES WILL BE CUT AND THE RESULTING SHOWER OF SPARKS WILL TURN YOU INTO A 4TH OF JULY BBQ--ONLY THIS TIME, YOU ARE THE ONE ON THE GRILL. But you can always look at the bright side...you will be FAMOUS within 3 days as you will have over a million views on You Tube
