Old 08-25-2007, 01:58 PM
priobe's Avatar
priobe priobe is offline
Cobra Make, Engine: E-M Cobra Ford FE 427 w/ Webers 48 IDA
Default Tilton Manual brake question
Hello all,
I am using a Tilton manual brake setup. I would like to find out from you guys running the same system, if you are using a return spring for the brake pedal.
If you are not using a return spring to bring the pedal back to proper height how did you accomplish this.
Any feed back will be apprieciated.
Thanks
