Old 08-26-2007, 08:56 AM
jmarsey's Avatar
jmarsey jmarsey is offline
Cobra Make, Engine: A Blue Car
The break pedal should return on its own. The use of a return spring should not be necessary and could be dangerous if the plunger rod is not captured at both ends. Tilton makes several different pedal assemblies. Which one are you using? Maybe you could post a pic of your setup. You should be able to adjust the pedal height by turning the threaded plunger rod in or out.
NASA - Instructor - 2012 TTA Champion - We Drive Harder!
