Old 08-26-2007, 07:49 PM
Rebel1 Rebel1 is offline
Sambo, either of the 70mm ones will do. That is either 40 or 45mm high.
The RMC is a little lower in the bodywork than say a CR so clearance is close, plus I suspect the RMC main rails are a little closer together so the engine cant sit between the rails.
There is also a drive shaft alignment issue but the dallow mounts make it way easier.
In your case with the Harrison you'd just use the mounts Warwick recommends.
