Old 08-26-2007, 09:00 PM
priobe's Avatar
priobe priobe is offline
Cobra Make, Engine: E-M Cobra Ford FE 427 w/ Webers 48 IDA
Let me clarify my situation. After bleeding my system the pedal does return, but it does not return to the original height. When adjusting my brake light bracket I notice after a few brake pedal usage my brake lights remain on indicating to me that the pedal is not returning to proper height.
Question #1 - Should I have to remove the balance bar or disconnect 1 side to bleed the system when bleeding it with the 2 person bleeding process?
The system that I am using is a Tilton (2) 3/4 brake front separate from rear and a 7/8 clutch. This is a manual braking system.
