Old 08-27-2007, 06:20 AM
Automan Automan is offline
Its difficult to tell right now if it right. If you torque it to the specs of mustang 2 suspension then you should be ok. Now when you have your car sitting on the ground with tires, engine and body:then when you go and lift the body by the wheel well and it stays at that position instead of dropping back down on it's own. You know that something is binding like mine is doing right now. My tire is still rubbing. I think i am going to lower my rear end by a hole or two and see what happens.
Automan
