Thread: getting hot
Old 08-27-2007, 10:26 AM
vettestr's Avatar
vettestr vettestr is offline
Cobra Make, Engine: Cobray-C3, The 60's body lines on todays chassis technology
David,
Have you found any trade off or down side to shrouding the cooling fans only and not the core? Did you need to increase the fans CFM from the full shroud design fan? You mentioned the aluminum small blocks were slow to reach oil temp with uncovered oil coolers on street cars. Do you run oil T-stats as standard configuration or is that more on the owners side of the coin?
Thanks for the input and lessons learned.
Jeff C
Jeff Classic
Manufacturer of the Cobray-C3
www.cobrasnvettes.com
