Old 08-27-2007, 12:39 PM
priobe's Avatar
priobe priobe is offline
Cobra Make, Engine: E-M Cobra Ford FE 427 w/ Webers 48 IDA
This leads me to a second question.
I just got off the phone with Tilton and the tech told me that I need to bleed the front and the rear at the same time. Here is the procedure.
1) Jack up the right side of the car with front and rear tires in the air.
2) Wait 30 - 45 minutes
3) Insert tube into a container and hook up the other end to the bleed on caliper
4) depress pedal several times and have 2 people bleed the fron and rear at the same time.
Repeat process for other side.
Is this the method you guys are using to bleed the system with balance bars?
Also what brake fluid are you using?
