Old 08-27-2007, 01:06 PM
jmarsey's Avatar
jmarsey jmarsey is offline
Cobra Make, Engine: A Blue Car
Invest in a good power-bleeder and be done with it. Otherwise, disconnect the balance bar and bleed one caliper at a time. This way you will know each line and caliper is solid. Also, on the caliper, make sure the bleeder is the highest point. Builders don’t always think about trapped air when deciding on the caliper location. By disconnecting the balance bar you can also see if it’s the front or rear master cylinder that giving you a problem.
John
http://www.hrpworld.com/index.cfm?fo...ction=category
NASA - Instructor - 2012 TTA Champion - We Drive Harder!
