Old 08-28-2007, 10:12 AM
Terry Stapley's Avatar
Terry Stapley Terry Stapley is offline
Cobra Make, Engine: Shell Valley, 418W, tremec 3550tko, 9" ford rear, 3.0 gear, silver/black
In searching for the intermittent no start problem I found the following:
The wire going from the neutral safety switch to the small plug-in on the starter must have gotten a bit warm as the shrink to fit plastic that was covering the crimp on plug was gone and about 1/4" of wire was showing. The end looked a bit heat fatigued so I installed another plug and then shrink to fit tubing.
Knock on wood but it started every time Friday when I drove it to work and then again on Saturday during a Utah Cobra Club drive in the mountains. A total of about 18-20 starts. Keep your fingers crossed and I will do the same!!
Terry
