Old 08-28-2007, 06:12 PM
lineslinger's Avatar
lineslinger lineslinger is offline
Cobra Make, Engine: 427 S.O. Dual Quad / Cobra undecided
Originally Posted by Rick Parker
I believe the above is courtesy of ERA's Website and should be so noted and credit given...........................
Rick, good call, I posted that same pic in an attempt to help someone else out and someone at ERA got in a real twist about it, I didn't realize it was their diagram, still, nice of Tony to post it.
MaSnaka,
If you are only showing 25 psi OP at 4500 rpm that engine will cook. There was a lengthy thread on this same plumbing issue just a few weeks back.
It turned out the owner had a pressure relief valve installed backwards. I will try to find the thread.
