Old 08-28-2007, 09:13 PM
MaSnaka's Avatar
MaSnaka MaSnaka is offline
Thanks guys! I am trying to aquire the larger pan asap. My plumbing is definetly going to the cooler first and the filter last before returning to the engine. Do you think this would this affect oil pressure?
Next on the running the pan dry issue- If I park and let the engine rest for say 30 minutes, I still have 25 psi. on restart. I would think oil would return to the pan while the engine is off and if so I should regain a higher psi until the pump is sucking air again. Also I have looked at the oil on the dip stick after a drive and it appears normal (no bubbles).
Thanks for your drawings, and the lead on the pan for sale, most helpful! I just hope it's still available.
John
